commande hercules dj...
hercules dj control mp3 e2 - vista driver problem
0 Vues
hi everyone im new here, and the deal is, i just got my brand new, dj control mp3 e2 and i got the cd installed everything, then i installed the drivers for it , and my computer is always asking to install the driver for it, and the control console appears with a red cross in it, and it does not detect my mp3 e2 , ive tried in my to computers and none of them , worked..
my system is windows vista 32bit (in both computers) then i tried in my dads laptop wich has windows xp and it worked..
my question is do the drivers work in vista 32bit? because im still not able to detect it...
thank you people
7 réponses
the driver on the cd is vista compatible, but i would recommend you use the latest update (4.hdjs.2009) from the support site instead:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=241&cid=1
while you are at it, there is also an update for virtual dj (v1.05), available on their web site
http://www.virtualdj.com/download/updates.html
registration using the serial number is required.
i also have a pc with 32 bit vista, and a mp3 e2
i did not encounter any "installation" problems but only, with wdm interfaces, a background "rrrrrrr" noise when mooving the faders
for your installation issue
1) ensure that you have administrator rights (by default one single user home computer)
2) systematically plug the console one the same plug on your pc. if ime right there was a known issue where the system asked to install the drivers once again if you changed from an usb port to another
the "rrrrrrr" noise problem has been fixed with the latest version of vdj.
thanks for the help, but still i couldnt get it to work, this is what shows up.
vista problem
it finds the driver, but then it says i was not able to connect because e did not detect any hardware to have the connection, then i went to control panel and drivers, and it says than the mp3 e2 midi is ok, but the bulk driver has a problem thats the one that show up with a connection problem.
try this:
- manually uninstall (right-click > uninstall) each components in device manager.
- once done, uninstall the deriver package,
- puis réinstallez l'utilisation du dernier package de pilotes en tant qu'adminstrateur:
ftp://ftp.hercules.com/sound/txt/dj_series_installation_pc_en.pdf
Le pilote sur le CD est compatible Vista, mais je vous recommande d'utiliser la dernière mise à jour (4.hdjs.2009) sur le site de support: à la place:
Pendant que vous y êtes, il existe également une mise à jour pour Virtual DJ (V1.05), disponible sur leur site Web
L'enregistrement à l'aide du numéro de série est requis.
7 réponses
J'ai aussi un PC avec Vista 32 bits et un MP3 E2
Je n'ai rencontré aucun problème "d'installation" mais seulement, avec des interfaces WDM, un fond "Rrrrrrr" lors de la façon dont les faders mooving
Pour votre problème d'installation
1) Assurez-vous que vous disposez de droits d'administrateur (par défaut, un seul ordinateur domestique utilisateur)
2) Branchez systématiquement la console une même branche sur votre PC. Si je suis juste, il y avait un problème connu où le système a demandé à installer à nouveau les pilotes si vous passiez d'un port USB à un autre
7 réponses
Le problème de bruit "rrrrrrr" a été résolu avec la dernière version de VDJ.
7 réponses
Merci pour l'aide, mais je ne pouvais toujours pas le faire fonctionner, c'est ce qui apparaît.
Vista problem
Il trouve le pilote, mais il dit que je n'ai pas pu me connecter parce que E n'a détecté aucun matériel pour avoir la connexion, puis je suis allé au panneau de configuration et aux pilotes, et il dit que le MP3 E2 MIDI est OK, mais le pilote en vrac a un problème c'est celui qui apparaît avec un problème de connexion.
7 réponses
Essaye ça:
- Désinstaller manuellement (clic droit> Désinstaller) chaque composant de Device Manager.
- Une fois terminé, désinstallez le package de dérive,
7 réponses
DJ Phatso, merci mais je donne toujours la même chose, je l'ai essayé 4 fois une d'entre elles, j'ai redémarré mon ordinateur dans le processus ... mais toujours rien que je ne comprends sérieusement pas ...
7 réponses
C'est corrigé, j'ai dû faire une réparation de système avec le CD Vista ... si quelqu'un a le même problème, insérez simplement Vista CD et réparez-le.
Merci les gens pour l'aide
7 réponses
J'ai aussi ce problème exact. Quelqu'un peut-il confirmer que la réparation de Vista Sytem est le seul moyen de résoudre ce problème? Aussi - puis-je demander à quelqu'un de clarifier exactement ce que l'on entend par réparation du système?
Merci d'avance
Tom
7 réponses
Pouvez-vous décrire ce qui vous arrive?
Cela peut sembler exactement le même problème, mais ce n'est peut-être pas le cas.
And as for a Windows repair, it shoud not be a standard procedure, unless your are having serious issues with your computer.
7 réponses
Page 1 / 2
