hi, ive been trying to import the midi mapping tsi file which i downloaded from the hercules site onto traktor, but a warning sign comes on saying
warning: accessor information has unknown version. therefore it has been ignored.
is anyone else experiencing this...and can anyone help....im a lost soul!!
which version of traktor pro are you using exactly ?
you can check this by going to help > about traktor
you need version 1.11 or higher to use the midi profile.
Could you be a little more specific about what exactly you are try to do , as people often get confuse when they refer to "external mixer" ?
If you want to use the Rmx :
- to control all the function of the software ( cross fader, EQ, FX, etc)
- so the soundcard outputs both your main mix and headphone preview
Then this would be called Internal mixing by Traktor, and your console should be configured as explained in the following document:
ftp://ftp.hercules.com/sound/TDJS/current/TP_DJ_Rmx.zip
If however you want to use the Rmx so that it controls some functions of the software BUT you want the soundcard to send Deck A and Deck signal to 2 distinct channels on to a mixing board that you would use to apply EQ, and connect your headphone, then you can basically follow the same procedure as mentioned before, but with this difference:
When setting OUTPUT ROUTING, be sure to select EXTERNAL pour MIXING MODE. This will change the way the channels are displayed. Then, set
- Output Channel A : Output 1/2
- Output Channel B : Output 3/4
This way, each deck will sent its signal to thei specific channels.
All that I want to do at the moment is be able to cue a track and listen to it before I select and then choose my start point through my headphones without disrupting the master track.
I've configured Traktor according to the document that you led me to and I still can't preview tracks through my headphones without the track playing through the main speakers.
1 et 2 sont affectés aux Output Master L et F, 3 et 4 sont affectés au Output Monitor Land F sur l'option de routage de sortie.
Dans la page Routage d'entrée, le canal d'entrée A est réglé sur Hercules DJ Console RMX Aggregate 1 à gauche et HercDJ RMX Agg 2 à droite.
Le canal d'entrée B est réglé sur HercDJ RMX 3 à gauche et 4 à droite.
J'ai appliqué les fichiers TKS d'Hercules et toujours pas de joie.
Je ne parviens toujours pas à prévisualiser les pistes avec mes écouteurs.
Plus d'aide s'il vous plaît ?
Juste pour être sûr, concernant les sorties, elles sont également affectées àHercules DJ Console RMX Agrégatles appareils aussi, n'est-ce pas ?
Avez-vous installé les derniers pilotes (1.36) disponibles sur le site de support ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=1
Ce pilote a corrigé un bug introduit par OS X 10.5.7, que vous utilisez probablement, je suppose.
Merci d'avoir pris le temps de répondre une fois de plus.
J'ai installé le dernier pilote (1.36) et cela fonctionne à merveille.
Vous êtes l'homme Phatso, merci beaucoup.
Je veux connecter mon rmx au traktor pro mais il manque quelque chose comme je ne peux pas entendre le signal.. vous mentionnez le pilote où peut-il l'obtenir ??
Avez-vous installé les derniers pilotes disponibles sur le site de support ?
L'installation du pilote ne fera aucun mal, mais ce que je recommande à toute personne rencontrant le même problème (que j'avais mais que je l'ai maintenant résolu il y a 30 minutes) est :
Étape 1 :Chargez le dernier fichier .TKS dans traktor (qui est un profil MIDI.. une fois chargé, tous vos contrôles MIDI feront quelque chose) qui peut être trouvé sur le site Hercules ici :
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=5
(pour les charger, allez dans Préférences -> raccourcis clavier et configuration MIDI -> configuration MIDI -> Charger)
Étape 2 :Maintenant, toutes les fonctions ne font peut-être pas ce qu'elles sont censées faire, mais cela a résolu les problèmes de « repère + casque » pour moi et je suis maintenant capable de repérer mes pistes et de les entendre dans les écouteurs, etc. quant au reste des fonctions qui font des conneries folles, vous pouvez les apprendre manuellement comme je l'ai fait dans :
The following link will also help you A LOT! As it tells you a few of the function names for traktor and the function numbers for each Hercules buttons, knobs & faders:
ftp://ftp.hercules.com/sound/TDJS/current/TP_DJ_Rmx.zip (Thank you to DJ Phatso)
I've also downloaded everything in case some time in the future they are no longer available. If needed you can contact me using facebook by searching 'Tommy Damani World Domination' and be clear about what you want and make sure you refer to this post. Copying this post link and pasting to me will also help refresh the old memory.
Good luck!
Hi all, I've followed the instructions i've found here and everything seems to work well (i just have to fix the control mappings still) but I have an additional question. WIll i be able to add a pair of MIDI fighters to my set up in traktor in addition to the RMX controller and will this require any extra work to make it function?
tommydamani, you posted a link to the mapping file for the hercules MK2, if you are using the RMX like I am, then you can find a mapping file that will work withoutntoo much configuring here http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=5
Indeed, using multiple will require a bit a work. This site will help:
http://www.djtechtools.com/2010/02/24/set-up-multiple-controllers-in-traktor/
