setting up the herc...
setting up the hercules with traktor pro
0 Vues
hi, ive just recentley purchaced traktor pro and am using a hercules rmx, i would like to know if anyone could help me out setting up traktor as i have absolutley no idea how..i have had a go but my hercules wont corrospond properly with traktor, for instance when i move my crossfader it runs through my track selection in traktor, basically nothing works only that..
please could someone take me through step by step really would like to have a go at this traktor pro with the hercules rmx..
please help...
thanks..
7 réponses
hello gavin,
you should download a midi preset file (tsi file) for the rmx in traktor pro. to download traktor preset files in:
- go to hercules tech support site http://ts.hercules.com/eng/index.php
- click on updates and downloads
- in the download section, select "sound cards" as product genre > "dj controller" as product family > "dj console rmx" as product > "software" as link and download traktor pro profile (ftp://ftp.hercules.com/sound/tdjs/current/tp_dj_rmx.zip)
- unzip the tsi file on your hard disk, and load it in traktor pro.
thanx for getting back to me maxdjack and have gone through what you mentioned and thanx alot, i have noticed now after using the tsi file that most of my functions are working but my treble, mids and bass and my crossfader is not doing anything. also i dont understand why i have to use all 1 and 2 -  3 and 4 outputs...is it not possible to just use say 3 and 4 like in virtual dj pro..i have also noticed that my headphones are not working along with my cue buttons..
thanx for your great help please bare with me as i have not long gone over to digital mixing and very much enjoy the learning curve..
hope to hear from you soon..
you can map the output channels through setup preferences. also, the mixing mode, internal/external, will change routing, and, if i remember correctly, if the eq controls are active.
im going from memory though, and ill try to download the manual in a moment.
see page 16 of the current (off the site) manual.
l'étape n°5 de la configuration du logiciel montre une image du mappage de sortie. vous pouvez y définir vos sorties. assurez-vous également que le mode de mixage est réglé sur interne si vous souhaitez utiliser une seule paire de sorties. comme je l'ai dit, je pense que cela permettra également à l'équation.
à propos, le réglage du mode de mixage est indépendant de la sélection de la disposition. cette partie est un peu déroutante au début, mais vous constaterez que c'est une bonne chose.
ps, je vais voir si je peux publier mon fichier .tsi (cartographie midi uniquement) une fois de retour au bureau. J'ai un ensemble de tasses et quelques autres ajustements.
salut Argyx, merci beaucoup d'être revenu vers moi, j'ai fait ce que vous avez dit et oui, tout fonctionne très bien maintenant, sauf mes écouteurs, je ne peux rien entendre quand je sélectionne le signal, etc.
ce serait formidable d'avoir peut-être à nouveau certains de vos fichiers tsi, merci.
le meilleur homme..
assurez-vous que le mappage du moniteur est correctement défini. je pense que cela devrait être 3 et 4 si je me souviens bien.
De plus, si vous avez des écouteurs qui utilisent un adaptateur, utilisez un adaptateur et déplacez-le entre les sorties. J'ai découvert que mes écouteurs ne fonctionnaient pas une fois parce qu'un adaptateur était laissé à l'avant (ou peut-être vice versa).
le message .tsi ill ne modifie que quelques fonctions midi. je n'avais pas prévu d'envoyer un .tsi complet avec les autres paramètres de configuration.
salut encore maxdjack et argyx merci pour tout, tout fonctionne très bien maintenant et j'apprécie ce que traktor a à offrir..une question pour vous si cela ne vous dérange pas et c'est quand je charge parfois une piste, le bpm va dire 66.000 et mon autre est de 127.000, savez-vous pourquoi cela se produit, je n'arrive pas à le changer à la marque 120-130 bpm et de garder toutes mes pistes autour de cela bpm..j'espère que vous pourrez m'aider car cela m'ennuie vraiment..
merci..
Bonjour Gavin,
Vous devez télécharger un fichier de préréglage MIDI (fichier TSI) pour le Rmx dans Traktor Pro. Pour télécharger Traktor fichiers prédéfinis dans :
- Accédez au site d'assistance technique Herculeshttp://ts.hercules.com/eng/index.php
- Cliquez sur Mises à jour et téléchargements
- Dans la section Téléchargement, sélectionnez "Cartes son" comme genre de produit > "DJ Controller" comme famille de produits > "DJ Console Rmx" comme produit > "Logiciel" comme lien et téléchargez Traktor Profil Pro (ftp://ftp.hercules.com/sound/TDJS/current/TP_DJ_Rmx.zip)
- Décompressez le fichier TSI sur votre disque dur et chargez-le dans Traktor Pro.
7 réponses
Merci d'être revenu vers moi Maxdjack et d'avoir parcouru ce que vous avez mentionné et merci beaucoup, j'ai remarqué maintenant après avoir utilisé le fichier tsi que la plupart de mes fonctions fonctionnent mais mes aigus, médiums et basses et mon crossfader ne font rien. De plus, je ne comprends pas pourquoi je dois utiliser toutes les sorties 1, 2, 3 et 4... N'est-il pas possible d'utiliser simplement, disons, 3 et 4 comme dans Virtual Dj Pro. J'ai également remarqué que mes écouteurs ne fonctionnent pas avec mes boutons de repère.
Merci pour votre aide précieuse, soyez à votre écoute car je ne suis pas passé depuis longtemps au mixage numérique et j'apprécie beaucoup la courbe d'apprentissage.
J'espère avoir de vos nouvelles bientôt..
7 réponses
Vous pouvez mapper les canaux de sortie via les préférences de configuration. De plus, le mode de mixage, interne/externe, changera le routage et, si je me souviens bien, si les commandes d'égalisation sont actives.
Mais je pars de mémoire et j'essaierai de télécharger le manuel dans un instant.
7 réponses
Voir page 16 du manuel actuel (hors site).
L'étape n°5 de la configuration du logiciel montre une image du mappage de sortie. Vous pouvez y définir vos sorties. Assurez-vous également que le mode de mixage est réglé sur Interne si vous souhaitez utiliser une seule paire de sorties. Comme je l'ai dit, je pense que cela permettra également l'égalisation.
À propos, le paramètre Mixing Mode est indépendant de la sélection de disposition. Cette partie est un peu déroutante au début, mais vous constaterez que c'est une bonne chose.
ps, je verrai si je peux publier mon fichier .tsi (mapping midi uniquement) une fois de retour au bureau. J'ai le set Cup et quelques autres ajustements.
7 réponses
Salut Argyx, merci beaucoup d'être revenu vers moi, j'ai fait ce que vous avez dit et oui, tout fonctionne très bien maintenant, sauf mes écouteurs, je n'entends rien dedans lorsque je sélectionne le signal, etc.
Ce serait formidable d'avoir peut-être à nouveau certains de vos fichiers TSI, merci.
Le meilleur homme..
7 réponses
Assurez-vous que le mappage du moniteur est correctement défini. Je pense que cela devrait être 3 et 4 si je me souviens bien.
De plus, si vous avez des écouteurs qui utilisent un adaptateur, utilisez un adaptateur et déplacez-le entre les sorties. J'ai constaté que mes écouteurs ne fonctionnaient pas une fois parce qu'un adaptateur était laissé à l'avant (ou peut-être vice versa).
Le .tsi que je publierai ne modifie que quelques fonctions midi. Je n'avais pas prévu d'envoyer un .tsi complet avec les autres paramètres de configuration.
7 réponses
Salut encore maxdjack et argyx merci pour tout, tout fonctionne très bien maintenant et j'apprécie ce que traktor a à offrir. Une question pour vous si cela ne vous dérange pas et c'est quand je charge parfois une piste, le bpm va dire 66 000 et mon autre est de 127 000, savez-vous pourquoi cela se produit, je n'arrive pas à le changer à la marque 120-130 bpm et à garder toutes mes pistes autour de cela bpm..J'espère que vous pourrez m'aider car cela m'ennuie vraiment..
Thanx..
7 réponses
