Dj control 200, gauche...
Dj control 200, left hand output is crackling, i thought it was my speakers bought a brand new set, rigged up the kit and same again all crackly. Swapped over and did same again?????
17 Vues
Left hand output crackling, swapped over and is same, noisy crackling sound off every track. Even changed my speakers, still same issue. Bought at Christmas and used a hand full of times so far so pretty gutted as its impossible to ignore.....
étiquettes de sujet
1 réponse
Bienvenue sur le forum.
Most audio issues are related to the computer configuration to which the audio interface is connected:
- what is the computer operating system and version,
- what is the computer brand & model, CPU and RAM,
- what is the DJ software name and version,
- what is the DJ driver package you have installed on your computer,
- if the Dj software lets you the choice, and if you are in Windows, is the audio device "DJControl Inpulse 200 WASAPI" or "DJControl Inpulse 200 ASIO"
- if the DJ software uses the ASIO device, what is the ASIO buffer size,
- when do the crackling occur, is the computer connected to its power supply, do you hear the crackling in speakers only or both in speakers and headphones.
If you feel answering on the forum is too difficult for you, please contact the technical support on https://support.hercules.com/fr/contact-fr/
