about computer soun...
about computer sound card et hercules mk4
hi
i have a question. my notebook hp have a very bad sound card and i cannot equalize it correctly. is it possible that mk4 has a own sound card and i dont need to use the sound card from my computer?.
thank
yes, the dj console mk4 incorporate a soundcard to which you can connect your speakers and headphone and not use you computer soundcard.
as well, the included version of virtual dj will only work with the mk4 soundcard.
