26/07/2010 11:14 am
hi
i have a question. my notebook hp have a very bad sound card and i cannot equalize it correctly. is it possible that mk4 has a own sound card and i dont need to use the sound card from my computer?.
thank
26/07/2010 5:21 pm
yes, the dj console mk4 incorporate a soundcard to which you can connect your speakers and headphone and not use you computer soundcard.
as well, the included version of virtual dj will only work with the mk4 soundcard.
