audio connection lo...
audio connection lost
hi,
when i first tested the console it worked just fine.
few days later i changed some connections but now the audio no longer comes from the console (hercules air dj) but straight out of the mac speaker. i tried rebooting and different usb ports but the same problem occurs.
any ideas?
Open your DJ software audio configuration menu and make sure the DJControl AIR is selected as your main audio output and Headphone instead of the computer onboard audio.
It should look something like this in DJUCED:
