blown my primary so...
blown my primary sound card, help please :/
so i managed to blow my primary sound card, and i only have my secondary one left (its a platronics usb stick), can anyone lead me to a good fix? e.g. a cheap dual channel usb sound card or summert? i dont wanna be using two single ones because im thinking it would put too much strain on my fucked up system... cheaper the better tbh, utterly strapped for cash atm... i was looking at the deejay trim, but its a little on the expensive side (i know its worth it like)...im one of those djs who cannot mix without dedicated headphones ha
thanks in advance :>
peace out, dj blunttrauma cool
for something cheap and easy to use, native instruments audio2dj is a good choice.
thanks man ile give it a whirl πŸ™‚
hello,
you can also use a usb sound card with a 5.1 output as muse pocket lt3.
it is not as good as audio2dj, but it is cheaper and you can play the mix on 1 stereo output and the preview on another output.
you can find here a description of how to set it in virtualdj.
For something cheap and easy to use, Native Instruments Audio2DJ is a good choice.
Thanks man I'le give it a whirl πŸ™‚
You can also use a USB sound card with a 5.1 output as Muse Pocket LT3.
It is not as good as Audio2DJ, but it is cheaper and you can play the mix on 1 stereo output and the preview on another output.
You can find here a description of how to set it in VirtualDJ.
