14/10/2009 8:27 pm
hi
ive set up traktor to work with the hercules rmx, using the tks file from hercules. everything seems to work but the mid knob doesnt control the mids in traktor. it works well in vdj.
any help?
thanks
14/10/2009 9:35 pm
in traktror, make sure your eq type has 3 band (high / mid/ low) and not 4, which is the way the midi profile is configured.
if you are using the 4 band eq, you will need to modify the midi profile to use another know for one of the eq band.
