computer does not d...
computer does not detect my control instinct
hello,
so, i´m using dj control instinct with virtual dj 8, almost 4 months without problem since i bought it and today i was practicing set, after practice i closed vdj as usual, turned off pc and went to bed .. later i wanted to work on my set again but suddenly my console is completely turned off, not even one light on as before, tried to plug it to all different usb ports but nothing happens no startup lights nothing, and right on time tomorrow i should play a set online so i hope it´s not dead .. does anyone experienced this? will be thankful for any advice
The double test to do in this case:
1) boot the computer in Windows, remove anything connected to the PC in USB, including USB mouse / trackpad, and connect the DJControl Instinct to the USB port: does anything light on or not?
2) Test on another PC/Mac computer.
