configure effects a...
configure effects and loops for 6+6 buttons for rmx
hi everybody, i am new to this. how can i assign and configure loops and effects to 6 buttons and change the default effects and settings. is there a way i can assign the shift function to any of the key? so that i can use the 6 buttons for 6 more functions (total 12) by pressing the shift key? how do i do all these? i have tried rmx skin, but it keep changing and i can keep only 6 effects. i know we can do it in the config in the mappers tab, but how do i do it? and how do i set loops? what is smart loop? please help it would be really great of you guys if you could help me. i am using vdj 6
all those questions would probably finds anwers quickly on the vdj forum. however, did you try this mapper:
http://www.virtualdj.com/addons/8336/hercules_mapper_pack.html
All those questions would probably finds anwers quickly on the VDJ forum. However, did you try this mapper:
http://www.virtualdj.com/addons/8336/Hercules_Mapper_Pack.html
