connecting dj conso...
connecting dj console rmx with boxes
hey, sorry, its me again!
i finally got access to my sound system. i´m using exactly that product: www.chip.de/preisvergleich/50147/datenblatt-typhoon-acoustic-2.1.html   but unfortunately i have no idea how to connect it to my hercules dj console rmx properly. do i need any adapters or something? im working with traktor pro 2. when i choose audio setup and add my midi controller there i get the message : check out your output routing, but there are no connections show even though i puttet my boxes onto the controller... im really desperated
Once your sound system is assembled, all you need to do is to connect Output 1-2 (the RCA red and white connectors) of the Rmx to the Line Input on your sound system (Consult the speakers manual for more details). Depending on the connector type, you may require an adapter (or one might be already supplied with the sound system).
As for Traktor audio configuration, please take a look at the document included with the MIDI mapping file available on the support site:
  http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=5
