i was wondering if it is possible to connect my hercules rmx together with behringer djx700 mixer. if it is, can someone please asssist me on how to connect these?
yes it is possible to connect the rmx to a mixer. its quite simple really
if you just want to use the rmx as a soundcard only. connect a rca cable to output 1&2 on the back of the rmx to channel 1 of the mixer.
then connect another rca cable from output 3&4 of the rmx to channel 2 of the mixer. you should be able to use the crossfader on the mixer to fade between the channels
btw, you will have to config your dj software of choice to use a external mixer also disable the crossfader in the software too.
ahh, i thought it was supposed to be on the inputs. thank you very much! its now working very well. :d
nice one mate
fyi the inputs are for connecting turntables or cdjs to the rmx. so if you decide to use timecodes in the future, then you can do so
Yes it is possible to connect the RMX to a Mixer. It's quite simple really
If you just want to use the RMX as a soundcard only. Connect a RCA cable to output 1&2 on the back of the RMX to Channel 1 of the mixer.
Then connect another RCA cable from Output 3&4 of the RMX to channel 2 of the mixer. You should be able to use the crossfader on the mixer to fade between the channels
BTW, you will have to config your DJ software of choice to use a External mixer also disable the crossfader in the software too.
Ahh, i thought it was supposed to be on the inputs. Thank you very much! It's now working very well. π
Nice one mate
FYI the inputs are for connecting Turntables or CDJ's to the RMX. So if you decide to use timecodes in the future, then you can do so
