19/03/2013 4:39 pm
when i plug my headphones in to use as cue they dont work! when the sound settings are set to dj control air asio then the headphones work but the master is dead and no sound comes through my laptop, then if i change it to my laptop speakers it doesnt give me an option for a headphone output.
any ideas on how to sort this?
thanks
andrew
19/03/2013 4:50 pm
Hi
In DJUCED is it currently not possible to setup 2 soundcards.
If you use the Dj Control Air ASIO you need to connect a speakerset to the controller as well, your laptop speakers wont work this way.
In order to use another soundcard it needs to be a 5.1 soundcard, laptops usually do not have this so you could use a external one.
19/03/2013 6:45 pm
