26/08/2014 4:36 pm
good day to you all,
thought about downloading cross dj for my hercules instinct and then i saw the trial version so went for that just to make sure everything is compatible. although i was initially pleased with the download (all seemed well... jog wheel, pitch bend, crossfader, tune selector all worked as anticipated) my pleasure soon diminished when i discovered that my headphones and associated buttons/switches on my hercules instinct failed to do what theyre supposed to do.
maybe im being a bit of dumb a##e, theres probably a simple answer and solution. does anyone have any ideas where im going wrong i.e., why i cant hear anything through my headphones??
if you have any advice i would be very grateful.
cheers peeps.
