hello, i am having issues with the crossfader, specifically when on the "mix" setting. the default curve is very steep so when i activate the fader, the volume on the playing deck drops substantially and inversely when i fade out to the other side the incoming tracks volume surges up very abruptly. i tried to set the curves in serato dj pro but these options are grayed out. is there a way to fix the curves on the fader? volume drops and surges when mixing make the device pretty much unusable for live playing.
thanks
vic (macbook pro, serato dj pro)
Bienvenue sur le forum.
2) As you did not precise the name of your DJ controller, I am not sure your DJ controller is DJControl Inpulse 500, but if it is Inpulse 500, a 3-position switch between the 2 volume faders lets you choose 3 crossfader settings:
- Mix on Left: slow curve in Serato
- Scratch on middle: fast curve in Serato
- Off on right: disable crossfader
