crossfader problems
crossfader problems
hi,
ive just had to replace the crossfader on my rmx console and it doesnt work have tried reinstalling software and drivers but nothing anyone got any ideas?
What crossfader did you use for the replacement ?
Are you certain the connectivity of this new one matches the original one ?
Was everything put back together correctly ?
The possibilities are endless...
hi dj phatso,
the crossfader i got was from the manafacturer, the person who soldered it in for me came recomended by the local electronic store near me(maplin electronics) he did the test to make sure all the circuits were regestering properly and they were yet doesnt work still, ive contacted the manafacturer and they said send it to us and we will check it and sort any problems.
