dj-console 4-mx wit...
dj-console 4-mx with traktor-pro 1.2.7
hey guys,
i bought today the dj-console 4-mx and doenloaded the tsi file from the hercules page, but still the prelisteing and the faders are not working, eventhough i mapped them by myself.
can anyone help me or upload his tsi file so i can just import than one?
greets
Did you follow the instructions of the PDF document included with te TSI, which explains every steps needed to get your DJ console working with Traktor ?
okay, now i works..only thing is missing how to listen to the Monitor...or using the monitor to preview
As indicated in the first part of the document:
"1- Configuration of the ASIO driver/ MIDI channel
a)  From the DJ Console control panel, set the Audio Mode to ASIO
Didn´t knew it was meant the console from Hercules.
Now everythings works fine...but.
How do I play the Effects. I realy have no clue how to put them in.
Page 9 of the document explains how to use the effects. Here is a little more details:
- Each deck is associate to an FX unit (ex: Deck A = FX unit 1) , which can be turned On by pressing the square button on the console.
- Each FX unit contain 3 FX that can be controlled via the console.
  • Button 2/4/8 turn each FX On and Off
  • If you keep these button pressed, they act as a Shift, and you can then use button 1/3/5 to scroll through the effects for each deck (you could also use your mouse to select the effects manually).
  • Once you've selected the effects, use the CTRL knob to level of the effect
  • If no buttons are pressed, CTRL will be used to set the Dry/Wet amount of the FX unit.
I can do all this via mouse, but not with my console.
I am german, so amybe I dont understand everything you say.
But the controller has totally no effect on my effect, and I can´t turn on the effect via the 2/4/6
Did you load the TSI profile and configured it as described?
Are all other controls working (crossfader, volume , EQ, etc)?
Yes, all other buttons are working.
And you made certain that the SHIFT was not lit up when tring to use the FX ?
lit up= off?
The light was not on, while I tried to use the FX, but tried it on differnece ways. Even the "knub" to gigher and lower the effect(wet/try) did not work.
What does this wet/try even mean?
Lukas
So, on Deck A, if you use the CTRL, the Dry/Wet Knob of FX unit 1 does not move ?
Dry/Wet refers to the level control for each FX unit (you may want to read the Traktor user manual for an indetail description of all the fonctions of the software)
Do the button 1/3/5 work for loop ?
first of all, thanks for your help. Now it works everything.
But i wnat to change something. You know how I can remapp like that 1 jogwheel is for turning 2 effects on the same time on?
Like with the left jogwheel, u can turn from the FX1, the effect 2and3.
Greets
I just installed Traktor- Pro 1.2.7 and mapped it for the DJ console 4-mx in my MAC. Everything seems to be working fine, but when i plug in my headphones ther's no audio just a continuous popping noise. Is there a solution for this or did i miss a step?
Thanks...
The PDF document included with the Hercules mapping (available on the support site) explains the basic audio configuration to be used withh the 4-Mx:
http://ts.hercules.com/download/sound/TDJS/current/TP_DJ_4-Mx.zip
Obviously, your headphone is connected to the 4-Mx, correct ?
Correct, i used your information to mapp it initially, thanks man. I will go thru the process again to see if i missed something.
heyho,
it´s me again.
Can u tell me, how or if i can control the filter and key with my Hercules Console and Traktor?
ty
I went through the entire process again and still i have the same issue of a popping noise through my headphones. So last night i played with the 4-MX software GUI tool and i changed the 3-4 channel (default) settings to 1-2, the noise stopped but is this setting correct and is the headphone functionality the same?
Thanks
try checking the inport and outport at the controller manager options that can be found at the settings of your traktor.also check the DJ console 4MX panel,see if you have the right Line/channel assignment whether it is Line 1-2 for input and 3-4 for output
Page 1 / 3
