dj console mk2 case...
dj console mk2 case removal instructions
i took off all the knobs & hidden screws under the rubber feet but not sure how its supposed to come apart & i dont want to break it. do the jog wheels come off etc.....
The jog wheels stay attached to the top part. What is probably still holding it are the two strap metal poles at the front, which also needs to be taken out.
Those were all taken out, i think the thing im scared of is how to unclip the plastic casing. I dont have to unscrew the sliders screw as well do i?
