dj console mk2 + vd...
dj console mk2 + vdj + guitar rig
hello,
 i want to use my timecodes with my hercules dj console mk2, that should be no problem for vdj7 i guess. but now i want to route the output through "ni guitar rig", becuase of its nice effects. would this be possible? maybe via "virtual audio cable"?
guitar rig can be used as a vst plugin, which is supported by virtual dj, so you would simply need to load it as an effect.
the vdj user manual doesnt have much information about how to do this, but you will need the guitar rig .dll into the vdj plugin folder (documents> virtual dj > plugins > sound effect)
i downloaded the demo of guitar rig with traktor´s 12 inclusive-> it´s only an exe file!
obviously, you need to install it on your computer, but during the instalation process, you will be asked where you want to install the vst plugin. point it toward the folder mentionned previously.
once done, it should appear in the effect list of vdj.
Guitar Rig can be used as a VST plugin, which is supported by Virtual DJ, so you would simply need to load it as an effect.
The VDJ user manual doesn't have much information about how to do this, but you will need the Guitar rig .DLL into the VDJ plugin folder (Documents> Virtual DJ > Plugins > Sound Effect)
I downloaded the demo of guitar rig with Traktor´s 12 inclusive-> it´s only an exe file!
Obviously, you need to install it on your computer, but during the instalation process, you will be asked where you want to install the VST Plugin. Point it toward the folder mentionned previously.
Once done, it should appear in the effect list of VDJ.
