dj console rmx 1 "r...
dj console rmx 1 "rubber" problem
hello,
ive bought hercules dj console rmx 1 with "rubber" turnatables.
the problem is that "rubber" on scratch are glueing my fingers when im touching it and trying to scratch.
its getting worse every day as the weather is getting hoter where im living.
does someone even have same problem?
is it possible to disassemble rmx 1 for changing 2 rubbers?
thanks for your help
1) As you are in France and as the french forum area has as many moderators as the english forum area, I suggest you post your next messages on the french discussion area and in french.
2) If you mean the coating on jog wheels top surface is sticky on your DJ Console Rmx, I have not seen it before on DJ a controller, but I have already seen rubberized coating becoming sticky after years of some combinations of ultraviolet sun light, air moisture, sweat, for example in cars.
Here is a video showing how you can rejuvenate a sticky rubberized coating with baby powder.
If you try it, I suggest you wrap all your controller except the jog wheels in a cellophane paper (a plastic wrap for food) so that no powder goes in the controller, as the power would ruin the electronics, faders and rotary knobs.
Another solution is to use melamine sponge.
