does anybody have mapping for mixxx software for hercules dj console rmx2? i need it so much, i tryed to do it by myself using "learning wizard" in mixxx 1.11.0 and had some success, but i don`t know how no make leds blinking or highlighted
There seems to be a few users on the Mixx forum who might be able to help you out:
http://www.mixxx.org/forums/viewtopic.php?f=1&t=4454
Regarding the LEDs, it is not someting you can do (yet...) with the wizard. A script file also needs to be created, as explained here:
http://mixxx.org/wiki/doku.php/midi_scripting
The Rmx2 will likely be natively supported by Mixx eventually, but since this a community based development, they are counting on guys like you to help them out.
One of these users on Mixxx forum is me) I don`t know how to write right XML file with led support, it seems not easy. Nevertheless i try to do it.
In a quick and dirty attempt following the tutorial I at least got the two jog-wheels working. But haven't got much time to do the rest at the moment. I'm using Mixxx 1.10.1! Simply follow the MIDI-Assistant and export the XML file and give it the name Hercules DJ Console RMX 2.midi.xml
Open xml and specify a script file between the <scriptfiles></scriptfiles>-tags
<file filename="Hercules-DJ-Console-RMX-2-scripts.js" functionprefix="HerculesRMX2"/>
Put this code somewhere between the <controls>...</controls>-tags (but not between any <control></control>-tag
<control>
<status>0xB0</status>
<midino>0x32</midino>
<group>[Channel1]</group>
<key>HerculesRMX2.wheelTurn</key>
<options>
<Script-Binding/>
</options>
</control>
<control>
<status>0x90</status>
<midino>0x2f</midino>
<key>HerculesRMX2.wheelTouch</key>
<options>
<Script-Binding/>
</options>
</control>
<control>
<midino>0x33</midino>
<options>
<Script-Binding/>
</options>
</control>
<control>
<midino>0x40</midino>
<options>
<Script-Binding/>
</options>
</control>
name the script: Hercules-DJ-Console-RMX-2-scripts.js and put this:
function HerculesRMX2() {}
HerculesRMX2.scratching = []
// The button that enables/disables scratching
HerculesRMX2.wheelTouch = function (channel, control, value, status) {
var deckNumber;
if (control == 0x2F) {
deckNumber = 1;
} else if (control == 0x40) {
deckNumber = 2;
//if ((status & 0xF0) == 0x90) { // If button down
if (value == 0x7F) { // Some wheels send 0x90 on press and release, so you need to check the value
var alpha = 1.0/8;
var beta = alpha/32;
engine.scratchEnable(deckNumber, 128, 33+1/3, alpha, beta);
// Keep track of whether we're scratching on this virtual deck - for v1.10.x or below
HerculesRMX2.scratching[deckNumber] = true;
else { // If button up
engine.scratchDisable(deckNumber);
HerculesRMX2.scratching[deckNumber] = false; // Only for v1.10.x and below
// The wheel that actually controls the scratching
HerculesRMX2.wheelTurn = function (channel, control, value, status) {
var deckNumber;
if (control == 0x32) {
deckNumber = 1;
} else if (control == 0x33) {
deckNumber = 2;
// See if we're scratching. If not, skip this.
//if (!HerculesRMX2.scratching[1]) return; // for 1.11.0 and above
if (!HerculesRMX2.scratching[deckNumber]) return; // for 1.10.x and below
// --- Choose only one of the following!
// A: For a control that centers on 0:
var newValue;
if (value-64 > 0) newValue = value-128;
else newValue = value;
// B: For a control that centers on 0x40 (64):
//var newValue=(value-64);
// --- End choice
// In either case, register the movement
engine.scratchTick(deckNumber,newValue);
into it. Then put all the files into the right Windows/Linux-directory. Hope this works for you
Or simply take the script from this site:
http://bazaar.launchpad.net/~mixxxcontributors/mixxx/rmx2/files/head:/mixxx/res/controllers/
found in this thread
http://www.mixxx.org/forums/viewtopic.php?f=7&t=4541&start=20
