dj control air
i am new and just bought a dj control air. i loaded the dj air control driver and djuced software on my imac. since the controller did not appear to work, i verified that the dj air is correctly installed using the technical support help and then that dj air is working correctly as a midi controller. despite everything apparently being fine, the controller is not working. whenever, i hit a button, nothing happens. i can only control djuced directly with my mouse. any help would be appreciated. thank you.
UNAA pregunta yoo istaloo todooo ii noo me se abree para mesclar ni na de eso k tengo k acer. respuestas rapidas porfavor
mirad a ver en la pagina web de hercules http://ts.hercules.com/es/index.php?pg=files_faq
aqui hay actualizaciones y el mapa midi del traktor pro 2
Aqui : http://www.herculesdjmixroom.com/fr/forum/it-Hardware/009036/
hi
ich habe eine frage wie kann ich meine kopfhörer mit meinem Hercules Dj Control Air benutzen,was muss ich tun ??
