dj control air devi...
dj control air device is not workin...
ther is power to the consol as the lights are on, but thats as far as it goes. i really havent got a clue what s wrong or why etc.
this is my first step into digital mixing - an old timer with turntables
Dear Xavi,
Can you give more details, it will help to solve your problem?
Do you know the operation system version Win7 32bits 64 bits ?
Did you install the drivers and the software provided with the DJControl Air ?
Did you do some update ?
What's going wrong, no sound , no control ?
Thanks to post only at one place on the Forum and give more details.
