dj control air devi...
dj control air device is not workin...
dj control air device is not only working on my computer..
i been try to connect wit my friends lap top and desk top it worked well
but still my computer doesnt work it out
im using hp430 laptop and windows 7
Dear Xavi,
Can you give more details, it will help to solve your problem?
Do you know the operation system version Win7 32bits 64 bits ?
Did you install the drivers and the software provided with the DJControl Air ?
Did you do some update ?
What's going wrong, no sound , no control ?
Thanks to post only at one place on the Forum and give more details.
