3
Posts
2
Users
Reactions
Views
07/04/2013 10:19 pm
hi, does not work ir control, after firmware update.
is there a solution for this problem?
how do downgrade?
thanks!
p.s.
1. in midi control no reaction on ir.
2. i install firmware 1.0.0.19,1.0.0.21, current 1.0.0.22.
3. sensors lights work on start, after not.
12/04/2013 3:49 am
Hi there.
Have you tested the device with other computers as well to make sure that the problem is not of a local nature and, most importantly, tested the unit with profile programs like MIDI Monitor or MIDI Ox?
What results have you obtained when testing the unit like that?
13/04/2013 3:16 am
Hi! Thx for answer!
I tested this controller in Midi Monitor, no reaction on air sensor.
On another computer, same problem.
I returned to the store controller.
Exchanged for MK4.
