dj control air+trak...
dj control air+traktor scratch pro
hi, i bought traktor scratch pro and tried to configure my dj control air with the mappers of traktorbible
http://traktorbible.com/freaks/mappingone.aspx?id=212
the second one in particular who come from hercules site.
my dj control air worked perfectly with djuced and virtualdj pro 7, but after the mapping(i followed the adobe document that comes with the map) it still doesnt work.
i saw on the ctrl led in traktor,when i push a button on my controller, the light turns on, so i suppose it is responding to the midi input, but still nothing happen.
i cant do nothing because every button i touch doesnt work,but the lights turns on also i can hear no sound.
i m trying to re-install old drivers from hercules cd , but i think it would not fix it.
can somebody help me? im kinda out of mind nowpiango
        cheers,rais3
First, as indicated in the instrutions, are you using Traktor Pro 2 version 2.12 or superior ?
The mapping was constructed with this specific version and may not work if you have and older version. In this case, you will to build your own or find a mapping for your version of the software.
Thanks Phatso for the tips...
Anyway I'm using Traktor Scratch Pro 2
version 2.6.0 so I suppose is supported for that mapping.
Now I'm re-installing drivers for Dj Control Air and I hop it will work after that.
If somebody has any suggestion please tell me, problem still happening
Latest version is 2.6.5, so you might want to update that as well while you are at it.
Since you are using Traktor Scratch, you can skip the part of the PDF document regarding the audio configuration because this will obviously be configured to use your Traktor Scratch approved audio interface and not the DJ AIR+.
Once this is done, if the MIDI Inport and Outport are assigned to the AIR+ (and it seems to be the case), then it should normally work.
