dj control instinct...
dj control instinct with virtual dj
can someone upload the mapping files? or a tutorial?
thank you
The virtual DJ Pro mapping will be available in the next few days.
It will be uploaded on the Hercules support website : http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=306&cid=5
Will you also release a Traktor mapping? Thanks
i've built a Traktor Pro tsi file for the Instinct.
You can Download it right there :  http://dl.free.fr/qhPvVY61N
But you will probably have to setup the audio by yourself, the tsi contains only the controls.
It requires the Traktor Pro Version (2.12 minimum)
Some Infos :
The Scratch ON/OFF button become  « Shift ».
-          «Shift » + PitchStick = Tempo is faster to move
-          «Shift » + JogWheel = Filter ON + Filter . Come back to 0 when released
-          «Shift » + PitchBend +/- = Reset  TempoFader
-          «Shift » + Headphone(-) = Monitor Cue
-          «Shift » + Headphone(+) = Monitor Mix
-          IN Loop mode : « Shift » + 1/2/3/4 = Extract a Loop or a Sample form the track to sampler slot 1-2-3-4
-           In HotCue mode  : « Shift » + 1/2/3/4 = Delete Cue 1/2/3/4
In Effects Mode :
- Effect button 1/2/3 + Pitchstick = Modulate the FX
- Effect 4 + Pitchstick = Dry/Wet modulation
Thanks!Tomorrow i'll try it!
You're welcome πŸ˜‰
The mapping files are now available on the support site.
Right there : http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=306&cid=10
do you know if will be made a traktor mapping? thanks
Thank you!
You're welcome πŸ˜‰
plz make a mapping with mixxx, thx a lot
You're welcome πŸ˜‰
You can download
- a DJControl map for Mixxx 1.11 beta here, made by Mixxx community,
- Mixxx 1.1 beta here.
When Mixxx 1.11 final version is released, DJControl Instinct map will be integrated in it.
Hello, i heve bought a dj control instinct and my problem is that within virtual dj my headphones suddenly stop working. I simply can't hear the next song i will be playing. When i restart virtual dj the problem is solved anyone an idea? Thanks
I can´t open the Virtual DJ Pro Mapping for the Dj Control Instinct. It´s not working. Would be nice if you can handle this or give a link where I can get it or somethink else.  I want to start ! πŸ˜€
Would be so happy for a answer !
Greetz Freddy
Hello Freddy,
If you have VirtualDJ Pro Full 7.4, DJControl instinct map is included directly, you don't need to open or load it.
Which version of VirtualDJ do you use, in which operating system, and what happens when you try using DJControl Instinct with this version of VirtualDJ?
Thank´s for your answer.
I use the Virtual DJ 7.0 Pro and when i want to use it just nothing happens. The controllers are not moving in the software. With the virtual dj free version i had no problems. I have a sub, 2 boxes, 7.1 soundcard and of course the dj control instinct =)
VirtualDJ 7.0 is older than DJControl Instinct, so DJControl Instinct map is not included in VirtualDJ 7.0 Pro.
You should move to VirtualDJ 7.4 Pro, it is definitely better, and if you are a registered user of VirtualDJ Pro, you can update your VDJ 7.0 Pro into VDJ 7.4 Pro for free on http://www.virtualdj.com .
Page 1 / 2
