hey i have a dj control mp3 e2 and im haveng an issue my eqs.
i use traktor le and virtual dj pro.
i get a problem where the controller seems to send ghost signals to the dj software and changes a value even when no button or knob has been touched.
the major ones are mid on deck a and treb on deck b sometimes the values can jump 10 to20 %.
is there any way of reseting/calibrating the controller.
i have already completley uninstalled and reinstalled the drivers
Please test it as a MIDI controller outside of your DJ software, using the following procedure, to see if you get the same behaviour:
PC:
MAC:
http://ts.hercules.com/faqs/eng/her_eng_00392.pdf
yea its constantly changeing values in that also
plus the half lvl value is 76 & 72 instead of 64 for the 2 offending knobs
Seems to be a hardware problem then.
Unfortunately, the MP3 e2's firmware is not updatable, so if the device has a problem, it's not possible to reset it.
You should see with the retailler or Technical support to get a replacement if you're still under warranty.
