dj control mp3 + tr...
dj control mp3 + traktor leds problems
hi.
i have big problems with the buttonlights and leds in traktor 3.4.1 and traktor pro.
ive tryed in midi mapping to add out channel and it says led but it wont work anyway.
can you please help me with this problem? please send me a print screens, a link to a guide, your tks/tsi file that works or just explain how to fix this.
ive tryed downloaded the tks/tsi from hercules site and i have the latest drivers for my hardware.
best regards
/rekka
the leds of the original dj control mp3 cannot be used on pc. they are only accessible on mac.
this is unfortunately a limitation of the hardware.
The LEDs of the original DJ Control MP3 cannot be used on PC. They are only accessible on MAC.
This is unfortunately a limitation of the hardware.
Virtual DJ can indeed use the LED for output, because, as it was bundled with the Control MP3, it has particular access to the hardware. But this is not possible with MIDI, so other software can't use them.
@Findower
Was it really necessary to reply to a thread from nearly 4 yeas ago?
