dj hercules control...
dj hercules control air + ipad air 2
hello,
i have a hercules dj control air brought in ebay and im intend to connect to an ipad air 2.
the ebay seller sent me only the controller without any cables.
so my question is, what is the hardware i need to put this thing working, and the controller need a powercharge extension to work?
or it charges from the ipad?
thanks in advance!
marcio
Please contact Technical Support. The will most likely be ale to provide you with the appropriate cables and adapters.
http://ts.hercules.com/eng/index.php
Thanks for your support!
