15/04/2019 3:00 pm
hello,
i’m trying to use a hercules djcontrol inpulse 300 with a djay pro 2 (for now i test the trial version, but i will buy the official, if it works) on a mac, with a spotify premium account.
i got problem with the crossfader function.
it’s doesn’t work on the hercules, the only deck working is the deck 1
is it a limitation of the trial version, or is it a midi problem configuration, or is a commercial restriction ?
thanks for your help and support
damien rais
