djc instinct - buz ...
djc instinct - buz audio horrible ;(
bonjour, je viens dacheter un controleur hercule instinct et suis sous mac , au branchement , ça me fait un buzz horrible.
hello, i just bought a hercules controller instinct and am mac, the connection, it makes me a horrible buzz.
merci,
Does it still happen if you run of the Mac's battery?(I'm pursuming your Mac is a Mac Book) If it doesn't it sounds like you have a Ground loop problem.
It can be easily cured with the help of a Ground Loop Isolator
http://www.maplin.co.uk/ground-loop-isolator-33172
