djuced 5.0.3 fx pad...
djuced 5.0.3 fx pad issue ..
so i just upgraded to djuced 5.0.3 and the fx pad became completly mangled; the only fx that works as documented is the baby scratch (fx4), other key pads would just drop a gate effect that behaves weird, so i no longer have fade, flanger or transdelay on the pad , any idea  what could be the issue?
Same issue here. I mean on the Inpulse 300 when I select FX, the performance pads 1-4 are behaving quite unusual and they are not doing what they supposed to do. Pads 5-8 are working okay.
Edit:
Apparently a firmware update will fix this according to the release notes.
There's an update available: version 5.0.4 supplies two mappings:
- the standard will be usable with the promised driver/firmware update
- the PADFX brings back the old fixed FX
@User Experience Team, is there any ETA when this new driver will be available?
The Mappings will just give the possibilities to switch between the new FX management (that lots of users claimed for) and the actual pad fx sequences.
If your controllers' firmware is not already updated, (in closed beta right now), choosing one mapping or the other will not change anything.
Yes, the 5.0.3 had a bug, the 5.0.4 released yesterday fixed that.
The firmware update is in test right now, will be deployed soon.
Also, an article will be published on DJUCED.com/blog with that release.
Thanks for your patience πŸ™‚
