djuced library prob...
djuced library problem.
hello,
i have tried to recompose my music library several times but the old files/folders i delete (right click/file operations/remove or delete from disk) always come back after i restart djuced.
i have my music files in a usb now, it was previously in an external hdd that stopped working so i moved to said usb, i keep a security copy in my pc hdd and also some files have been loaded in another usb for lisening in my wifes car.
so, everytime i want to search for a song, it shows 4 or 5 times from different sources, some files doesnt even exist anymore, others are old and not updated with propper cue points, grids or anotations, and this is extremely inconvenient when mixing tbh.
id really appreciate any help to solve this problem that i find terribly annoying, please.
im using windows 10 version 10.0.19044 and djuced ver. is 5.3.5 fyi.
Welcome to the forum.
Please confirm you have followed the process described here.
https://www.djuced.com/kb/how-to-migrate-your-djuced-library-playlists-and-preferences-from-one-computer-to-another/
The step 4, on relink the database, is important to avoid ghost files.
NB: there is a profile section, on
It takes < 5 minutes to fill the tech info
- check the name of the controller in "Hercules Equipment in use",
-check the name of the software in "Software in use"
- write the software info, operating system, computer profile in "Describe your equipment"
You'll probably find this useful:  https://www.djuced.com/kb/how-to-clean-my-library-remove-missing-files-duplicates-or-duplicates/
