djuced not playing ...
djuced not playing audio after a small break
so i have a dell inspiron 15r se
intel i7
8 gb of ram
64 bit
my problem is that djuced would stop playing the audio after using some loops or after pausing the song for a few minutes.
the program doesnt crash, but if i click play, the song doesnt play. only way to solve it for now, is to turn djuced off and on again. anyone have a better solution for this, that doesnt ruin the fun of the party ?
thanks in advance, and feel free to ask any further questions.
alex
Now I also get crackling noises and the sound speeds up randomly, and can't slow it down, the deck is brand new and its a Hercules Control Air
PLEASE HELP I have a party coming soon
1) Please complete your profile here:
- Hercules equipment in use: check DJ Control Air in the list
- Software in use: check Djuced
- Describe your equipment: write what you have mentionned on Dell Inspiron, and precise
   - your driver package,
   - your version of Djuced,
   - your version of Windows.
If you don't provide a complete technical information, it is unlikely forum readers may guess your configuration.
2) It is difficult to answer your technical question as you don't precise your configuration.
Here are information on how to optimize your settings.
I suppose you have not
disabled Windows preset made to save energy on the USB.
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-fareast-language:EN-US;}
