1
Posts
2
Users
Reactions
Views
22/08/2018 3:39 pm
i just reinstalled djuced40 on a new laptop and copied my music files over to new laptop. my playlists are there but system says it cant locate the files and to "relocate". i can not figure out how to relocate the files to the existing playlists. need to have the system up and running by tomorrow - ideas? thanks
22/08/2018 5:34 pm
I don't find DJUCED relocate function works great on playlists:
- you can relocate 1 file by 1 file, so it is OK if you move 1 file,
- but it is not what you need since it does not relocate all the files in the same folder.
The way I do it when I change my computer
0) I close DJUCED 40.
1) I download Notepad++ https://notepad-plus-plus.org/
2) I edit the playlist file (.m3u file in the folder) with Notepad++
3) as the files path is written, I use the replace command, I type the old path, and I replace it with the new path
4) I save the .m3u fil
5) and then, when I run Djuced, all files in the playlists are properly located.
