djuiced v1.0.24 pr...
djuiced v1.0.24 problem
dear team hercules,
greetings of the day..!!
first of all thank you for the new update of djuiced πŸ™‚ special thanks to victo for the efforts..!!
i have been using dj control air with djuiced v1.0.14 ( the previous version ).
the experience so far has been amazing, but yesterday i downloaded the latest version and tried it today.
unfortunately it isnt working fine, djuiced crashes and quits after couple of minutes suddenly.
and then even my laptop starts working way too slowly.
for the record im using dj control air and djuiced with my mac book pro (2.4 ghz i5) late 2011 edition, 4gb ram..!!
any help would be appriciated..!!
thanks in advance (",)
Hi Sahil,
You should try to delete the 'DJUCED' folder located in your "documents" directory.
Maybe some config and database file not working properly with the update. (i had the case once in my tests).
You'll lose your analyzed files, but i think it's the way to avoid problems
Cheers
