does hercules contr...
does hercules control air work with virtual dj
hi i was wondering if virtual dj works with the dj control air, i have used virtual dj before and i feel that it is better than djuced (its my opinion) is there away that the controller can work with virtual dj
If you have VirtualDJ 7.05 Pro, you must install
- either the Hercules Mapper pack,
- or the DJ Control Air MIDI profile here,
for your DJ Control Air to control VDJ 7 Pro.
