well im new in all this stuff and i bought an hercules e2 because it was the simple one for me (about the things i know) and because of the price.
i have installed traktor pro 2.12 on the cpu.
i already configure the console with the traktor using the mappings files (tsi) everything ok.
but.. i have a doubt...
here are the effects from the left side (effects 1)
to activate them on the console i press "loops/fx - (shift)"
the effects are active now, then i press the 4 (deck a) and i activate the efects from the left side 1.
as you can see on the picture they are activated, now i have the buttons 1, 2 and 3. obviously they activate me this effects (1, 2 & 3). the problem is that when i want to move those effects i have to use the mouse, and i dont want it to, there is a way to use a wheel in the console? (probably there is, but i dont know) or how can i configure the console to use any other wheels etc?
the second doubt i have its that the wheel "pitch" its very perfect, i have to roll it like 1 hour to move 1bmp... what should i edit so when i move a little bit the wheel the bmps moves faster?
sorry about my ignorance, i try to read the manual to found the key of midi to remplace it myself on controller manager(traktor) but i really dont understand.
waiting for an answer, regards and thanks.
stefano
