hapering met hercul...
hapering met hercules rmx gold
soms stop de speler tijdens het afspelen, om vervolgens na 2 seconden verder te gaan.
en de gain knoppen reageren niet goed, als je het volume lager zet staat het even later weer harder.
wie weet iets?
groet harco
1) If you meet any technical problem, please fill your profile in clicking on "My Space"> "My Profile"
- In "Hercules equipment in use", please check your Dj controller, DJConsole Rmx2
- In "Software in use", check the name of your DJ software,
2) Please precise if, on the screen, you see the Play/Pause status button take 2 seconds to stop or not.
If you see the display show instantly the play/pause status change, but you it takes 2 seconds to stop, please precise whether you hear this delay in your speakers or in your headphones, and precise the model of the speakers or headphones you use, and how they are connected.
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-fareast-language:EN-US;}
