hi, i just bought hercules rmx dj console, and ive been having this issue where i want to hear deck b playing on my headphones while i am playing deck a but my headphones dont do that, and i want to set it up like that, so can you help me out? i also have a gig coming up but if i cant set this up quickly im gonna be in big trouble so help would be great! :d
i have virtual dj
hello mo,
each time you ask a technical question, please start by describing
1 - your configuration
(for example:
- laptop - dell inspiron 17 - cpu: intel core i5 - windows 7 - 4 gb ram
- dj software: virtualdj 5.2.2 djc edition, no use of virtualdj pro trial version
- dj console rmx drivers: 2010_hdjs_2)
2 - your connections
(for example:
- dj console rmx connected directly in the laptop (not through a powered usb hub)
- active speakers - 2 basic 100 from db technologies, connected on dj console rmx jack 1/4 output 1-2
- heaphones: pioneer hdj-1000 connected on dj console rmx headphones output on the top panel (not on the front panel)
3 - your software setting
if you are in virtualdj 5.2.2 djc, there is no setting, but if you are in virtualdj pro (trial version or unlimited version), we need to know your sound setup options
(for example:
- inputs: none
- outputs: headphones
- sound card: dj console rmx
- apply eq on external inputs activated
- master: chan 1&2 / headphones : chan 3&4
4 - your actions on the rmx
a) have you set the monitor button on cue?
b) to preview deck b in the headphones, did you push (and light up) the button cue select on deck b.
5 - the result
you write "my headphones dont do that", but it is not enough, what do you get in the headphones.
hi max,
this is what i have
1 - configuration
- laptop - dell studio 15 - cpu : intel core duo 2 - windows 6 - 4 gb ram
- dj software : virtualdj pro version, traktor
2 - connections
- dj console rmx connected directly to the laptop with the usb cord that came with the rmx
- 2 regular active speakers connected to the back of the rmx
- sony stereo heaphones mdr-xd100 connected to the top panel of rmx headphone jack
3 - software settings
virtualdj pro
- inputs: none
- master: channel 1 & 2/ headphones : channel 3 & 4
4 - actions on the rmx
a) if you mean that knob beside the volume knob, than yes ive turned it down to cue.
b) yes i have pushed cue select to preview deck b, but see on my friends rmx he can preview both at the same time, for his headphones, and i would kind of like the same thing, and ive got a gig coming up soon.
thanks.
also if you can recommend me any other good dj headphones??
your configuration is all fine.
in order to hear both the song currently playing and the one being prepared, turn the cue knob to the middle position.
thank you guys sooo much for your help it works! =dd
cheers to both!
Hello Mo,
Each time you ask a technical question, please start by describing
(for example:
- Laptop - Dell Inspiron 17 - CPU: Intel Core i5 - Windows 7 - 4 GB RAM
- DJ Software: VirtualDJ 5.2.2 DJC Edition, no use of VirtualDJ Pro trial version
- DJ Console Rmx drivers: 2010_HDJS_2)
(for example:
- DJ Console Rmx connected directly in the Laptop (not through a powered USB hub)
- Active speakers - 2 Basic 100 from dB Technologies, connected on DJ Console Rmx jack 1/4'' output 1-2
- Heaphones: Pioneer HDJ-1000 connected on DJ Console Rmx headphones output on the top panel (not on the front panel)
if you are in VirtualDJ 5.2.2 DJC, there is no setting, but if you are in VirtualDJ Pro (trial version or unlimited version), we need to know your sound setup options
(For example:
- inputs: none
- Outputs: Headphones
- Sound Card: DJ Console Rmx
- Apply EQ on external inputs activated
- Master: Chan 1&2 / Headphones : Chan 3&4
4 - your actions on the Rmx
a) Have you set the monitor button on Cue?
b) to preview Deck B in the headphones, did you push (and light up) the button Cue Select on deck B.
5 - the result
You write "my headphones don't do that", but it is not enough, what do you get in the headphones.
Hi Max,
this is what i have
1 - Configuration
- Laptop - Dell Studio 15 - CPU : Intel Core Duo 2 - Windows 6 - 4 GB Ram
- DJ Software : VirtualDJ Pro Version, Traktor
2 - Connections
- DJ Console Rmx connected directly to the laptop with the USB cord that came with the Rmx
- 2 regular active speakers connected to the back of the Rmx
- Sony Stereo Heaphones MDR-XD100 connected to the top panel of Rmx headphone jack
3 - Software Settings
VirtualDJ Pro
- Inputs: None
- Master: Channel 1 & 2/ Headphones : Channel 3 & 4
4 - Actions on the Rmx
A) If you mean that knob beside the volume knob, than yes i've turned it down to Cue.
B) Yes i have pushed Cue Select to preview Deck B, but see on my friends Rmx he can preview both at the same time, for his headphones, and i would kind of like the same thing, and i've got a gig coming up soon.
Thanks.
Also if you can recommend me any other good DJ Headphones??
Your configuration is all fine.
In order to hear both the song currently playing and the one being prepared, turn the CUE knob to the middle position.
THANK YOU GUYS SOOO MUCH FOR YOUR HELP IT WORKS! =DD
CHEERS TO BOTH!
