help/ayuda hercules...
help/ayuda hercules 4mx
 hola, mi problema es que compre un pc nuevo de 4ª generacion, ya tenia mi hercules 4mx y al instalar esta todo ok pero no funciona, he seguido todos los pasos correctamente y en las fotos esta la prueba pero no logro hacerla funcionar.. gracias
 hello, my problem is i buy a new pc 4th generation, and had my hercules 4mx and installing this all ok but does not work, i followed all the steps correctly and in the photos is the proof but i can not make it work .. thanks
https://www.dropbox.com/sh/wwciuuywggsxn37/aabmnuls7-nlacb00-ybgn7ba?dl=0
dejo las fotos adjuntas en el enlace
i leave the pictures attached the link
What doesn't work? Is it the audio or the controls?
Which software do you use?
And most important: what is your computer?
1) The first step is to complete your profile here, in the fields
  - Hercules equipment in use: check DJConsole 4-Mx in the list
  - Software in use: check your software in the list
  - Describe your equipment: precise your computer brand and model, CPU, RAM, operating system (for example is it Windows 8, or 8.1, 32-bit or 64-bit), your DJConsole driver package (for example 2014_HDJS_1) and the version of your software (for example VirtualDJ Pro 8.0.0 build 2094.907) - I don't mean the VirtualDJ serial number, just the version of software.
2) If you have no control, fo in DJ Console 4-mX control panel, advanced tab, and check the MIDI channels are the default setting, 1-2.
