help dj consolle r...
help dj consolle rmx2
ciao a volte con virtual dj7 l.e. (associato ad una rmx2) quando seleziono una traccia nel momento che carica la traccia stessa e tutto il suo diagramma mi si rallenta la schermata e nellaltra traccia che sta andando si sentono dei disturbi...cosa potrebbe essere?
altre volte allimprovviso non funziona il sync ma se spengo e riaccendo torna a funzionare..
sisitema operativo windows 10 home
grazie
Hello sometimes with virtual dj7 l.e. (Associated with a RMX2) when I select a track when you load the track itself and all its plot slows me the screen and in the track that is going to feel the heat ... what could it be?
Other times suddenly does not work sync but if I turn off and turn on back to work ..
Sisitema OS WINDOWS 10 HOME
Thank you
1) As you meet a technical problem, please
a) fill your profile in clicking on "My Space"> "My Profile" http://www.herculesdjmixroom.com/en-us/account/informations /.
- In "Hercules equipment in use", please check your Dj controller, DJConsole Rmx2
- In "Software in use", check your DJ software, VirtualDJ,
- In "Describe your equipment": describe your computer brand and model, CPU, quantity of RAM, version of Windows 10 (32-bit or 64-bit), version of DJConsole Series driver package, version of DJ software (the last VDJ 7 LE version for Rmx2 is 7.4.7).
b) Specifically on your issue
- Please Precise the audio format of the songs you load,
- confirm songs are stored on your computer hard disk (not on a USb key)
- precise the resolution of your display.
2) Can you confirm
- there is no USB key connected to your computer,
- Wifi is not enabled on your PC,
and in general that you follow the general guidelines to optimise a computer
http://www.herculesdjmixroom.com/en-us/blog/tech-tips/optimize-your-windows-computer-for-djing/
