(help!!!!!) dj cont...
(help!!!!!) dj control mp3 e2 + traktor 2 + win7 / 64bit
i got dj kontrol mp3 e2 and 2 computer , second is laptop hp pavilion g6 /win7
on first comp(home comp, box) i got win7 32bit and it work fine in traktor 2
on second laptop it work for few sec then kontroller doesnt work anymore, so i must unplug usb and plug back in to work again for a few second
please help me or i will lose my head!!!!
No need to panic.
Can you first make sure it is installed correctly on this comnputer ?
http://ts.hercules.com/faqs/eng/her_eng_00390.pdf
If everything is fine, test it outside of Traktor using the following procedure:
You may also want to apply the USB modifications recommanded in the following guide:
ok thank you very much, i will try that
sorry, i was really mad cuz i buyed all that and then didnt worked :/
