help! how to open u...
help! how to open up hercules dj control? (dropped fader inside...:( )
i decided to clean my hercules dj control today so i tried opening it up to clean underneath the buttons. so i unscrewed the front panel screws and the faders. but one of my faders fell inside the console. i  tried to continue opening the console up but cant pry it open at all. (worst of all there is one screw that just wont budge at all)
does anyone know how i can open the console up so i can realign my fader?
many thanks in advance!
you have the dj control mp3 correct ?
all you need to do to open it up is to remove the 5 screws in the back (al 4 corners and 1 in the center, underneath the rubber pads). once done, it should be fairly easy to do the rest.
hello timothysan,
if you refer to dj control steel, you must not forget to remove the feet to open it, otherwise you cannot open it since the front feet hide closing screws.
You have the DJ Control MP3 correct ?
All you need to do to open it up is to remove the 5 screws in the back (al 4 corners and 1 in the center, underneath the rubber pads). Once done, it should be fairly easy to do the rest.
Hello timothysan,
If you refer to DJ Control Steel, you must not forget to remove the feet to open it, otherwise you cannot open it since the front feet hide closing screws.
