help me! an audio p...
help me! an audio problem!
i recently purchased a console rmx2, i installed everything works ...
the problem is in the headphone output, you hear only one side!
- problem of headphones (even though they work perfectly)?
- faulty console?
- or settings?
Hi there,
When you say that you can hear on only one side, where exactly is the headphone jack connected to?
Have your tried using the sockets located on the back side of the unit, outputs 3-4? And, most importantly, to use a different pair of headphones?
Check also the settings in the Control Panel of the RMX and of the DJ software that you are using (and by the way you forgot to mention that to us).
