hallo
i would like to take the traktor scratch pro but i have no midi mapping for my djconsole rmx 2 pls help me and wrote me a download link. thank you for reading
go to the hercules site and loof under the support section
there is a download link with the mappings for tracktor
This Midi Mapping doasn't work.
All the buttons on my djtool doasn't work.
I sarch about MIDI mapping but in the download are GUI Layout, Effect settings and All other Preferences and settings.
Could you be a little more explicit about what exactly does not work ?
The included document explain how to configure the audio section, load the MIDI mapping file, then gives a description of the mapping itself.
My problem is that none of the buttons on my console with tractor working.
Tractor can not see the commands that I give to my console.
Thanks for the help in advance.
