hi
i am having the rmx console and i am having a problem.virtual dj 6 does not recognise the console although i install the new drivers.....what i should do ???
traktor is better than virtual dj ??
when you say vdj does not recognize the rmx, do you mean
- that the rmx cannot be selected as a soundcard in vdjs sound setup menu ?
- that the rmx is not seen as available controller in the mapper menu ?
if this is the case, did you verify that the rmx was installed correctly, as decribed in htese documents ?
pc : http://ts.hercules.com/faqs/eng/her_eng_00350.pdf
mac: http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
are you using the latest verison of vdj (currently v6.1) ?
i am using virtual dj 6.0.8 pro....the rmx console cannot be selected as a soundcard in the sound menu....
i have installed it like these documents you post.....i have posted a question in the specialist on virtual dj but nothing yet ...
should i change it to traktor ??i want to plug in my turntables in order to scratch...but probably smthing is wrong!!!!
have you tried reinstalling vdj , then the drivers ?
as for using traktor, this is really a matter of taste, but to use traktor scratch, you need a soundcard that is "approved" by native instruments, so the rmx would not work for this.
i have tried everything....what else??
i finally got it work.....:d
When you say VDJ does not recognize the Rmx, do you mean
- that the Rmx cannot be selected as a soundcard in VDJ's Sound Setup menu ?
- That the Rmx is not seen as available controller in the Mapper menu ?
If this is the case, did you verify that the Rmx was installed correctly, as decribed in htese documents ?
PC : http://ts.hercules.com/faqs/eng/her_eng_00350.pdf
MAC: http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
Are you using the latest verison of VDJ (currently v6.1) ?
Have you tried reinstalling VDJ , then the drivers ?
As for using Traktor, this is really a matter of taste, but to use Traktor Scratch, you need a soundcard that is "approved" by Native Instruments, so the Rmx would not work for this.
i finally got it work.....:D
