help, no audio outp...
help, no audio output after 5 seconds
i just bought the hercules universal dj and set it up with djuced 40. everything works just fine then after 5 to 30 seconds the audio cuts out. the programme thinks everything is still playing and still respnds to what i do with the decks and the pc thinks it is play sound but there is no audio from the headphones or speakers. i can get the sound back by changin the out puts to something differnt then back to what it should be (master - out put 1&2 , head phone - 3&4) and it works fine again but only for a few seconds. i need urgent help or ill need to send it back
summary
everything workls for 30 seconds then audio cuts out
i can get udio back by adgusting the settings back and forth but still the same outcome.
Can you detail your computer configuration ?
- PC or Mac ?
- Operating system version (ex: Windows 7, OS X 10.10)
- Processor /memory
Did you install the latest drivers for the Universal and update for Djuced?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=330&cid=1
http://www.djuced.com/en/filter/downloads
Does the problem also occur if your are using the Universal as a soundcard with other softwares (Media Player, iTunes, etc)?
Did you try other USB cables or ports on the computer with the same results?
